The specified PDU type (LSP, CSNP, or PSNP) on the specified level failed authentication.
Check the authentication configuration of the nodes in the appopriate area (or L2 domain) to ensure that the correct nodes are enabled (or disabled) for authentication and are using the correct password(s).
Info
L%level%-%type%: authentication failed
| Name | Type |
| type | String |
| level | uInt |
